how do you control 3 pin fans?
DominicNikon
3pin fans are controlled by varying the voltage. If you're asking how it works on the software side, it's no different than controlling pwm fans.
do i go into the bios? my mobos software can only control 4 pins
yes, try going into your bios and set to dc control instead of pwm control if that's an option
-sigh- feeling like I'm being too negative lately
What motherboard do you have?
Very unlikely. Unless your mobo only has 1 fan header.
3 hours ago, DominicNikon said:
You should be able to control any 3pin fan with the sys_fan or cpu_fan headers using the motherboard settings.
Edited by WoodenMarker
ha i have the same mobo. and just bought 3 noctua industrial fans. and REALLY DO NOT like that i have to go into bios to change up the fan settings, not only that i dont understand the presets they have .75, 1, 2, 2.x
I hear about this SpeedFan a lot. but never a "safe" link to download it from.
23 hours ago, aisle9 said:
From experience, Gigabyte's mobo fan control is awful. Luckily, there's SpeedFan. It'll be your best friend.
How it works in the elgacy bios is .75pW, 1pW, 1.75pW and 2.50pW, literally dumbest stuff ever.
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
