Should i buy CPU cooler for locked i5?
Solved by typographie,
1 minute ago, shapeshifter.atm said:Its my case fans:
• Cooling system
Front: 2 - 120/140mm fans (included is 1 Fractal Design silent 120mm fan, 1200 RPM speed)
Rear: 1 - 120mm fan (included is 1 Fractal Design silent 120mm fan, 1200 RPM speed)Is it enough for good airflow?
Your fans look fine, and your CPU is probably fine. But a list of products doesn't actually tell us much.
The only way to make an educated decision about whether or not you need a new CPU cooler is your maximum load temperatures using your current cooler. I'm shocked no one has asked yet.
