Finished my first build the other night and didn't break anything! :lol:
Not the best looking rig, but it definitely fits my needs.  Going to be used for editing and some gaming.  I am planning on adding another 760 when/if the prices go down.  The processor is running SUPER cool, even when stressed, which is a huge relief...(I thought it would be a bit hotter with the small noctua.)  Anyways...super stoked and thought I would share.  :D
Parts:
CPU - Intel i7 4770k
CPU cooler - Noctua UB9 SE2
GPU - EVGA GTX 760 superclocked w/ ACX cooler
MOBO - ASUS Maximus VI Gene
Memory - 16GB (2X8) Corsair Vengence LP 1600
SSD - Samsung 840 pro 128GB
HDD - Seagate Barracuda 1TB
PSU - Corsair HX850
ODD - The cheap ASUS one...
Case - Corsair Obsidian 350D (window version)
https://linustechtips.com/topic/59957-first-build-complete/
remove that optical drive before i cry. plz.
This is my Lightsaber.          {[=]////]"[¬'/\Y/#####################################
This is my other Lightsaber. (T!!!!!!!T=:"|[\#####################################  #killedmywife
https://linustechtips.com/topic/59957-first-build-complete/#findComment-813826
Very solid first build.  Looks really good. Nicely done :)
3930k | RIVBE | 32GB Dominator Plat. | Titan XP | Intel 750 1.6TB | Mellanox 10Gb NIC | AX1200i
Custom TJ07 | 2xD5 pumps | EK Supremacy EVO | EK Titan XP | EK RIVBE Block | Cu Tubing | 25x120mm Rad
Samsung U28D590D 4K | Leopold Otaku w/Browns | Corsair M65 | Corsair SP2500 | Sennheiser HD595
https://linustechtips.com/topic/59957-first-build-complete/#findComment-813902
Looks really good. Congrats on your first build! Hope you'll get to enjoy it without any problems for a while.
Thanks!
Looks sharp. Couldn't use a 120mm cooler though?
mother of god nvm what is that monstrosity plaguing the front panel?
LOL YEAH WTH my eyes T,T
Pft...
needs work on the cable management, but I cut you slack because first build
other than that, nice job dude
Thanks.  I will have to rip into some cable management this week. :lol:
No.
Nice build. Start overclocking yet?
Thanks.  I'm running a conservative OC at the moment.  Ran IntelBurnTest and Aida64 stress test a few times and it seemed to float in the 38c to 45c range, which is awesome, right?.
Here is what it's OC'ed at for now:
https://linustechtips.com/topic/59957-first-build-complete/#findComment-813921
I wouldn't exactly ignore the people talking about the Optical bays. I removed mine after OS install, and it just sits in the cupboard for whenever I need to do a fresh OS install on a machine. Unless you truly have a use for it (which I would love to know. Most reasons I can think of that are actually warranted are if you use your PC to watch DVD's / Blu-Rays a lot).
https://linustechtips.com/topic/59957-first-build-complete/#findComment-814001
You should stealth your optical drive.  Other than that, awesome job :).
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
https://linustechtips.com/topic/59957-first-build-complete/#findComment-814190
Very nice build!
PS: Since I also use this exact same case and I also want to have an optical drive, I decided to put my internal one in an external enclosure so that the sleek front look of the case is not compromised by it.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/59957-first-build-complete/#findComment-814317
Good stuff. Neat looking build! :)
https://linustechtips.com/topic/59957-first-build-complete/#findComment-817789
Nice build! Not sure about the optical drive but i guess as long as you need it keep it. Those Noctua's actually look nice in there. Well done  :)
CPU: Intel Core i5 4670K | CPU Cooler: Coolermaster Hyper 212 Evo | Motherboard: Asus Z87 PRO | Ram: Corsair Vengence 8GB DDR3 | Graphics Card: Asus GTX 670 Direct CU II OC | SSD128GB Samsung 840 Evo  | HDD: 2TB Seagate Barracuda
Case: CM Storm Scout 2 | Monitor: 2x LG 22EA53VQ IPS
OS: Windows 8 Professional 64 Bit
https://linustechtips.com/topic/59957-first-build-complete/#findComment-820967
I use ODD's to burn data for clients. Why is it suggested I remove it?
Looks, primarily.
If you really need the optical drive (and it seems you do), then this
is definitely a suggestion I recommend looking into. It's usually not
a difficult mod to do and the results can be very rewarding. Ask if
you need help, but I recommend googling "stealth drive mod" or something
like that.
Generally a very nice build though IMHO, especially for a first effort. :)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/59957-first-build-complete/#findComment-821131
