Is there such thing as a 2 inch thick fan, and should their be?
Solved by ThomasD,
Yes, thicker fans would not only move more air, with proper design they could have much higher static pressure ratings (IIRC this is a matter of blade surface area and blade geometry.) But they would also consume a lot more power. Air may not seem like much, but it does have mass and causing it to move requires work. The more you move the more work gets done. The more work getting done the more electricity consumed.
But in some applications they would make good sense - thick radiators in custom loops - but you are going to need plenty of space.
