I do youtube here and there, have pc parts inbound for my first rig, but it doesn't have a GPU yet, I know you can stream on a cpu and a gpu but my question is will it destroy my cpu to stream on it? Obviously if I push its max threshhold without proper cooling and all that it will but I mean under a decent load but with the right cooling and stuff, will it lessen the life span? Should I wait until I can get a GPU and stream off that? BTW im talking about streaming through an Elgato HD60 and OBS, not talking about PC streaming, I mean PS4 streaming using the Elgato and OBS as helpers or w/e, even though the Elgato handles most of the work you still need a decent pc to run the software and encode/decode and all that.
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/597129-will-streaming-from-a-cpu-kill-or-harm-it/
You can do it even no notebooks with crap cooling, ofc you can do it on a regular desktop as well....
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
I figured not, but just wanted to make sure. On a side note what is the program Linus and his buddies use to test cpu temps and stuff? Jayz2cents also uses it, I wanna get it when I get my pc set up to make sure I have proper cooling.
CPU
Just now, babadoctor said:
anything will kill your cpu
lel
You staring at it might.
CPU
If you want to test your cooling, use Prime95. Techtubers usualy use AIDA64, but if you want to really evaluate your cooling capacity, Prime95 is the way to go.
It's also good for CPU and RAM stability testing, so that's a plus.
Um... no.
If you don't have a CPU cooler or something it would, but that's just because it's intensive load rather than the particular task at hand.
I sometimes stream with my crappy i3 and it's never broken lol.
let us all remember now and today, computers do not like abuse, they will fight back!
Old Skool KILLBOX. XEON E5640 4.0ghz / ASUS P6X58D-E ~ Noctua NH-L12 ~ eVGA GTX 670 SC 2GB 1312/7000 ~ 4TB 7200 RPM RAID0 ~ CoolerMaster Haf 922 ~ DELL P214H 23" 1080 IPS 2ms ~ HP w2007v 1680x1050. Now Playing: Splinter Cell OG XBOX / CSGO PC
Original XBOX - Xecuter 2 4981.67 Bios. Playstation 2 Slim SCPH-70002. Sega Dreamcast. N64
16 minutes ago, babadoctor said:
anything
over
time
will
kill
your
cpu
eventually
actually, only heat will
if you run 0.1v through a copper wire, it will last as long as a copper wire with 0v through it
this is because the first wire wont heat up with 0.1v
a CPU heats up, and that causes wear
more heat = more wear
Thanks all
CPU
