Suggestions for Case Fans
VoyexTech
Hi I need some fans for my new pc build and i was wondering if anyone knew lf the best fans to get for best airflow. I need 3 140mm high airflow fans and 1 120mm high static pressure fan. My budget is $60 USD up to $80. The also for any advice you can give me! :)
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
noctua, noiseblocker, bequiet, fractal design
Ok any pertucular fan? I am willing to pay up to $20 per fan.
My PC:
CPU: Intel i7 8700k
depends what looks and how quiet you want
I don't care about noise or looks for that matter the pc just lives under my desk and I never see it. All I care about is performance
My PC:
CPU: Intel i7 8700k
http://pcpartpicker.com/p/NPqGJx
They're a bit expensive but worth it imo. I think the redux version might be cheaper.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
GP-14's recently topped the 7V performance/noise charts in the most comprehensive (71 fans tested) 140mm fan review ever made.
So yea get those (also they are not expensive and come in black or white.)
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
I recommend the Fractal Design Venturi HP-12 for your pressure fan, and Noctua NF-P14s Redux for your case fans.
The amalgamation of reviews I have seen on the GP-14 fan is that it is not anything special. For one thing, it has a cheaper bearing rated for only 40,000 hours, compared to 150,000+ for the Venturi and Redux.
Phanteks offers some fans very similar to Noctuas and a bit cheaper, Noctuas nf-f12 is a solid choice for a radiator fan, the p12 if you're looking for a case fan
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
If you don't care about noise at all, you could just get Jetflos. For 140mm, There are 3000rpm NF-A14's for 140mm. These are very loud options though.
Somebody get this man a Delta. Let's make him regret saying that.
Aerocool DS are the best fans you've never tried.
I hope you mean the plane.
With Stage IV noise regulations in effect, it's probably quieter than the fans.
righto http://pcpartpicker.com/part/delta-electronics-case-fan-afb1212ghecf00  and  http://pcpartpicker.com/part/silverstone-case-fan-fhp141
desktop
HTPC
