Can an LGA 775 fan work with an LGA 771 motherboard?
EpicCookie
Go to solution Solved by Samsonsuperco,
First off, I don't see how you can put a GPU in that board with the slots it has... As for the coolers, I have a 771 board and I used heat sinks from a Dell Precision T5400 (which is my main desktop now). On socket 771, the heat sink screws go through the motherboard and into the chassis. I used serrated 6-32 nuts and the screws that are in the heat sink to mount mine. Just make sure you leave the metal bracket in place. You can usually pick up the heat sinks for around $25 a piece, and the nuts for around $5 on Ebay. Keep in mind that you need fans too. I just used zip ties to hold the fans in place. Hope this helps! (I will add pics soon)
So, my friend wanted me to build his new pc.
I got him 16 Gb of ddr2 ram, 2 Intel Xeons 5350, a SuperMicro X7DVL-E and an nvidia geforce gtx 750 ti.
I looked for some coolers for his cpu, and they were too expensive BUT i found Some lga 775 Coolers for WAY cheaper.
Will those coolers work with my mother board or not?
Please help.
The mounting holes are in different positions, so no.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
But WHY? Why do they change holes every time? It has literally nothing to do with socket functionality.. But anyway, they won't work but you can ghetto ziptie them down.
I need S340. But more Define S'ish
For lga 771 it was so they could use less board space on servers and put the cpu closer to each other.
MAIN RIG: Dell Precision T5500 -CPU: Intel Xeon W5580 (4c,8t@ 3.2ghz,turbo 3.46) -MOTHERBOARD: Dell Precision T5500 OEM -RAM: 16gb ECC DDR3 FBDIMM (Hynix) -GPU: Gigabyte GTX 770  OC WINDFORCE X3 -Case: Dell Precision T5500 OEM -STORAGE: 240gb ADATA Premier SP550 (OS, Programs), 2x 500GB WD Caviar WD5000AAKS (Games, Files) (RAID 0) -PSU: Dell Precision T5500 OEM (875w) -DISPLAY(S): Primary: Acer AL2016w (1680x1050), Left and Right: Gateway FPD1976W (1440x900), Extra displays around the room: 42" Vizio TV (1920x1080) -COOLING: Dell Precision T5500 OEM -KEYBOARD: Logitech G710+ -MOUSE: Logitech G502 Proteus Core -SOUND: Logitech x320 and Razer Electras -OPERATING SYSTEM: Windows 10 Pro x64
LAPTOP: Dell Precision M6500 -CPU: Intel Core i7 920xm (4c,8t@2.0ghz,turbo 3.2ghz) -RAM: 12gb DDR3 -GPU: ATi Firepro M7820 -STORAGE: 240gb ADATA Premier SP550 (OS, Programs), 500GB Seagate STL500LM000 SSHD (Games, Files) -DISPLAY: 1920x1200 17.3” -OPERATING SYSTEM: Windows 10 Pro x64
SECONDARY RIG: -CPU: 2x Intel Xeon x5450 (4c, 4t ea., 8c, 8t @3ghz total) -MOTHERBOARD: Corvalent BDPEX -RAM: 14GB ECC DDR2 (Mix Match of Brands) -GPU: Nvidia Quadro NVS 285 -CASE: No Case (Everything is mounted on the wall in my closet) -STORAGE: 160GB WD Caviar SE WD1600AAJS (OS, Programs, Files) -PSU: 450w BFG -DISPLAY: Samsung UN22D5000 (1920X1080) -COOLING: Dell Precision T5400 Heatsinks and some random fans -KEYBOARD: Logitech G105 -MOUSE: Logitech M215 Wireless Mouse -OPERATING SYSTEM: Windows 7 Professional x64
NAS: -CPU: Intel Pentium e2180 (2c, 2t@2ghz) -MOTHERBOARD: HP Compaq DC5800 OEM -RAM: 2GB DDR2 (Unsure of Brand) -CASE: No Case (Everything is mounted on the wall in my closet) -STORAGE: 500GB HGST (Backup) -PSU: HP Compaq DC5800 OEM (300w) -DISPLAY: Samsung UN22D5000 (1920X1080) -COOLING: Cooler Master Hyper 101a (Zip Tied) and some random fans -OPERATING SYSTEM: FreeNAS 9.10 (Running From USB Flash Drive)
FOLDING RIG: Dell Precision T5400 -CPU: 2x Intel Xeon X5450 (4c, 4t ea., 8c, 8t @3ghz total) -MOTHERBOARD: Dell Precision T5400 OEM -RAM: 32gb ECC DDR2 (Hynix) -GPU: Nvidia Quadro NVS 290 -CASE: Dell Precision T5400 OEM -STORAGE: 250gb WD 250ABYS (OS, Programs, Files) -PSU: Dell Precision T5400 OEM -DISPLAY: Dell 1707FP (1280x1024) -COOLING: Dell Precision T5400 OEM -OPERATING SYSTEM: Windows 10 Pro x64
PHONE: iPhone 7 32GB Matte Black (Sprint)
The motherboard actually has pcie slots
