How much heat from a heat emitting source (e.g. CPU) is turned into radiation?
Solved by Sunshine1868,
you'd be better served using the temperature differential between ambient and the cpu to power some kind of heat-engine (i.e. stirling engine) or using a thermoelectric generator to generate electricity
Featured Topics
TristenM ·
torlock ·
Posted in Troubleshooting0 -
1
Captain LeFwee ·
Hyperpower_BHAM ·
Posted in New Builds and Planning13 -
XxWOODSIExX ·
Posted in Troubleshooting1 -
Delano.888 ·
Posted in CPUs, Motherboards, and Memory11 -
1
DipwadDeluxe ·
Posted in Troubleshooting2
