Max temprature
LeifMeister
of what?
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
1 minute ago, EHasseltoft said:
The parts in a computer
Depends on what part are we talking about.
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
What temps are ur components running on?
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
When i just use google chrome and some few programs it is Cpu: 33°C and Gpu: 40°C
U got no experience of this stuff at all, huh?
Download "Open Hardware Monitor", play ur most resources-needing game for some half an hour and tell us your max temperatures.
What would you say is max temprature ??
Quote
40 minutes ago, EHasseltoft said:
What is the max tempratue ??
I'd say about 3.50
typical recommendation for intel, no more than 80ºC on cpu, gpu can get a little warmer like 90º   technically they can usually go higher but you start running the risk of damage if they don't throttle and behave like they're supposed to
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Max temperature is literally max you get with current hardware and cooler in most stressing situation. Like while running stress test. Then there's other temperatures which people refer with term "max". Max safe temperature is what you look when overclocking. Its something like 85-90C with Intel CPUs, 90C with GPUs and 75C with AMD CPUs. Max temp for certain configuration is what you tell us. Its good base to start troubleshooting anything temp related or to think if you need to change something in your cooling.
With stock cooling, you are looking at 75C normal gaming or high load temps on CPU, with 80C possible max under stress (I haven't run stock cooler in while). GPU will be around 75C too under normal loads. I would think 75C is good max temp for current gen GPUs.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
