Best CPU Air Coolers?
Tweed
Looking for a CPU air cooler. I plan to have an i7 6700k and an InWin 805 Case. I hear good stuff about Noctua NH-D15 and Phanteks TC-14PE, but both can't fit in my case according to pcpartpicker.
D14?
dark rock pro 3?
maybe some lower profile noctua cooler?
cpu cooler max height for your case is 156mm
hmm... NH-D9L or NH-L12
-sigh- feeling like I'm being too negative lately
Either Cryorig R1 Ultimate or be quiet! Dark Rock Pro 3.
Edit: Unfortunately, they also don't seem to be compatible. Probably either try the Scythe Mugen MAX or the other Noctua coolers.
where did you find out that information? im curious cause i couldnt find it.
http://inwin-style.com/en/gaming-chassis/805
Quote
Thermal Solution Compatibility
CPU Heatsink Compatible
- CPU die surface to side panel height: 156mm Maximum
the site is down for me :/
its displaying weird text for me but yea lol
Yeah ill check back later, but 156mm gotcha!
Ughh... why is my case so limited. not too many great 156mm air coolers.
best you can get is prob phanteks PH-TC14CS or noctua NH-C14S
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
11 hours ago, Enderman said:
D14?
dark rock pro 3?
Those are both near 160mm.
The best heatsink for this case would probably be a Ninja 4: http://pcpartpicker.com/part/scythe-cpu-cooler-scnj4000
Fun fact: You can attach 4 fans to it for double push/pull with some fishing line or rubber bands. I just did it with Gentle Typhoons out of curiosity several days ago.
