Need a thick soft cloth mouse mat.
AstroBenny
I currently have a thin soft mouse mat which spans my whole glass desk but unfortunately I find that if I'm using the mouse for more than an hour my forearm gets a little sore/uncomfortable due to the mat being so thin.
What thicker medium-sized mouse mat should I consider to put on top of my current mouse mat?
Thanks.
I don't like 2D games...I just couldn't get into them.. ( ͡° ͜ʖ ͡°)
Razer Goliathus Extended. It's a 3mm (0.12") mat.
I use the Speed version, it's a bit thicker than most cloth mousepads, but (to my taste) is equaly good.
There's also the Control, that feels a bit "rougher" to the hand but mouse glides almost exactly the same way as the Speed version.
|CPU : Core i7 4770 (non-K :( ) | GPU : XFX RX 480 GTR 8GB @ 1385Mhz | MoBo: Gigabyte GA-Z87-HD3 | PSU: XFX 850W PRO | Case: In-Progress Silverstone TJ-07 |
Zenfone 2 ZE551ml 32GB + 64GB SD - Rooted LineageOS |
Yes, that will increase the total paddedness.
Steelseries qck heavy (6mm thick)
Corsair mm200 (4mm thick)
etc. :D
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
I have to agree with @Mr.Meerkat, I have a Corsair mm200 and it has helped my accuracy as a gammer so much. Between the damn fine sensor within my g502 and the superior surface of the mm200, it's so much easier to be accurate with flicks and general movements. It's one of the best $15 I've ever spent on my setup.
ASU
