Noctua Fans Question
Tweed
Are the Noctua NF-A14 and F12 Static Pressure fans? For the US are they available still for the LTT (LinusTechTips) edition?
A14 is airflow and F12 is static pressure.
So not a good idea to have the A14 as radiator fans?
If aesthetics are priority then by all means use the A14. A static pressure fan will be more effective, though.
they still have more static pressure than most "SP" fans out there tbh
-sigh- feeling like I'm being too negative lately
Have the box right next to me, it says, "ideal for 140mm radiators"
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
I just want something that provides excellent airflow and quiet.
they have more than enough static pressure to perform great on radiators
they also have great airflow for no radiators
as case fan or for radiator?
Get the A the F are last gen.
well hopefully a14 on radiator pull config, f12 as rear exhaust and bottom of case as intake
the A14 will do fine on radiator
though you might wanna consider the NF-S12 for case fans (bottom intake and rear exhaust)
there is a dust filter on the bottom and a hard drive cage right next to it if that affects anything. also dont think there is a ltt edition for the nf-s12 unfortunately
i dont think LTT Edition fans are still in stock, or they are still available? o.O
the S12 is quieter than the F12, as well as move more air too, if there isnt any restriction
maybe Nf-F12 for the one with filter while S12 as exhaust?
but if you want black, Nf-F12 LTT edition is the way to go
They're good for rads. The A series are well rounded fans. The F12 is for focused flow which includes having great static pressure.
No, they're not last gen but instead a different series.
S12A's have a bit of static pressure and are fine for dust filters.
I thought they combined the two series into one series?
Just checked what I said is true for 140mm but not the 120mm
There's no NF-F14.
The A14s are still in stock, description says "the NF-A14’s Focused Flow™ system creates outstanding static pressure"
Ugh... I wish Noctua fans aren't the colors that they are. I would choose these fans but the color doesn't go well with my glass case with tempered glass.
I know the feeling, i bought the LTT versions just so I could get the black fins and then bought http://www.performance-pcs.com/noctua-na-savp1-chromax-anti-vibration-pads-white.html to get the correct color for my build.  In the end it cost more than any fan should...but I got my color :)
Have you seen checked out Phantek fans?
No, Noctua does not separate between airflow and pressure in 120mm. The A14 is meant to be an allrounder and it works very well both on rads and as a case fan indeed.
You can still get the A14 LTT, but the F12 is sold out: http://www.performance-pcs.com/140mm-pwm/noctua-nf-a14-pwm-special-linus-tech-tips-edition-140mm-cooling-fan.html
Alternatively, just get the 24V industrialPPC models (they run nice and quiet at 12V) and use the chromax pads.
A14 is not 120mm. I never said either can't play the role of static pressure and airflow simultaneously.
I will say, though, that using NFF12s as case fans is odd.
Their NF-P12 and NF-P14'S were originally advertised as pressure optimized fans and sold with their heatsinks while their NF-S12 was more oriented towards airflow and as case fans. By the time the NF-F12 came out with its focus flow and better static pressure, the P series had shifted to more of an all-rounder role.
