So I have had this mouse for a little over a year now and in the past few months I have started to experience some problems.
First problem was that my profiles kept defaulting to the third one and this would happen either when I first turn on the mouse or if i just hadn't touched it in a few minuets (like 7-15 mins).
I stopped that problem when I just turned off the other profile.
After turning off the extra profiles my dpi started to change on its own defaulting the the second slowest and it would switch the same way the profiles would (Either when i first turn it on or i just didn't touch it for a few mins) I Fixed this in the same way by just turning off the extra ones.
Now the last problem I had which was yesterday my main profile would just reset to the default settings that they were as if out of the box but only my main one.
I should also note that I am using on board memory and windows 10. Although I experienced the first issue on my chrome book when I was with out a computer for a few months. The other two were both on my windows 10 computer
https://linustechtips.com/topic/588854-problems-with-logitech-g700s/
