PWM Hub with 3-pin fans?
Surpuppa
Phanteks has a PWM hub on most of their cases. What happens if I plug in a normal 3-pin fan into it? Will I still be able to change its rpm?
Have a look here: http://www.tomshardware.com/answers/id-2205716/explain-3pin-4pin-fan-correctly.html
TL;DR - It should be possible
(\__/)
(='.'=) This is Bunny. Copy Bunny into your signature to
(")_(") help him on his way to world domination.
If it's this kind of hub on the case they are designed to take in a PWM control signal and provide an equivalent 3 pin DC voltage control signal as the output pins are only 3 pins:
So it will make my 3-pin fans quieter?
Well it gives them the ability to be varied in terms of speed but will still retain it's controllable range as a 3 pin DC voltage control fan.
Depending on what you set them to yes.
