Not sure where to plug h100i into mobo
Solved by W-L,
1 minute ago, Garrzilla said:Ok. My mobo has a water pump header, is that preferred over the CPU fan header?
There is no difference really between a CPU header and water pump header from when they first came out with them, it was thought they could provide higher amperage but most seemed to show the regular 1amp capacity as other headers on motherboards.
Featured Topics
Skipdiepipops ·
stefanmz ·
Posted in Console Gaming1 -
GokuGogo ·
Posted in Networking1 -
Void_dweller_ ·
Posted in New Builds and Planning2 -
3
22
9
SansVarnic ·
Posted in Phones and Tablets0
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
