Are my PC parts Good?
I am designing a new computer (obviously) and I want to know if my choices are good or if there are better deals out there and would like any input.
(http://pcpartpicker.com/p/hjP8WZ) updated version
I don't need a case.
Building the future and keeping the past alive are one and the same thing. - Solid Snake
(http://pcpartpicker.com/p/JJYRjX)
comments:
1) i wouldnt recommend getting a single rad AIO over an air cooler, either go with heatsinks or straight to dual rad
2) WD blacks are over priced, get a WD blue, and get 2tb if u can because it offers better value per gb
3) get a 380 if you dont need nvidia features
4) try getting an EVGA Supernova G2 550W PSU, its much better
-sigh- feeling like I'm being too negative lately
Yeah seems like a solid 1080p gaming machine. You´re good to order I´d say. Enjoy your new PC :).
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
Speaking as the owner of a WD Black drive, the difference in speed is not worth the difference in price. I'd dump the Black, replace it with a Caviar Blue, then put the savings toward a 120GB boot SSD.
I also wouldn't screw around with 120mm AIOs. They're outperformed by most high-quality air coolers. IMO, either go in for a 240mm AIO or something like an NH-D14/D15, R1, Dark Rock Pro, etc.
Also, speaking as a GTX 960 owner, many here will scream at you to ditch the 960, and for good reason. The R9 380 is faster at the same price point, but the 960 has some real pluses like lower heat (important if you're trying to save Celsius for a higher overclock), lower power consumption, and NVIDIA-specific features like Shadowplay. In most cases, imo, the 380 is the better choice.
Aerocool DS are the best fans you've never tried.
#TeamRed is the best choice for GPUs at almost all price ranges. (Well almost)
The Radeon Duo Pro should give the Titan X a run for its money (but the RDP might be more expensive than the Titan X?)
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
CPU: Intel Core i5-4690K 3.5GHz Quad-Core OEM/Tray Processor  ($219.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard  ($80.98 @ Newegg)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory  ($62.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($87.98 @ Amazon)
Video Card: XFX Radeon R9 380X 4GB DD XXX OC Video Card  ($195.49 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $777.30
Generated by PCPartPicker 2016-03-18 17:37 EDT-0400
The Pro Duo will outright BEAT the Titan X into oblivion. Also, @Josue9988
I advise spending a bit more:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($221.98 @ Newegg)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($92.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory  ($34.99 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($299.99 @ Micro Center)
Case: Corsair 100R ATX Mid Tower Case  ($39.99 @ Micro Center)
Total: $830.31
Generated by PCPartPicker 2016-03-18 17:46 EDT-0400
USEFUL LINKS:
PSU Tier List F@H stats
Total: $830.31
Additionally I'd say that if he could spend even $88 more he could get a nice SSD but I'm not sure how far he's willing to go.
I'm wiling to go to about $1000
Drop to the i5 6600K if you want to save money:
$1022
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($369.95 @ B&H)
Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard  ($94.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($76.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($56.99 @ NCIX US)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($309.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($48.99 @ NCIX US)
Total: $992.40
Generated by PCPartPicker 2016-03-18 18:39 EDT-0400
or if you do not need all the power:
$751
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($238.99 @ SuperBiiz)
Video Card: MSI Radeon R9 380 4GB Video Card  ($184.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($53.98 @ Newegg)
Total: $741.43
Generated by PCPartPicker 2016-03-18 18:44 EDT-0400
