Will a 390 fit? (Pictures provided)
Guun
Go to solution Solved by SeanAngelo,
6 minutes ago, Guun said:
I have been looking into getting a sapphire r9 390 nitro but keep finding different results for the length. The 37.5cm listed here: http://www.amazon.co.uk/dp/B019P30XUY/ref=psdc_430524031_t1_B0152WZYLU sounds much bigger than other things I have read which say 30, 30.8 and 33cm.
Given the size and concerns about my PSU ( http://www.coolermaster.com/powersupply/gx-series/gx-650w/) in my previous thread a 970 sounds like a safer option.
Can you guys provide me with an accurate size of the 390 and tell me which version of the 970 to get if it's not an option?
The Sapphire Nitro is 30.8cm.
The MSI card is 27.7cm
https://www.msi.com/Graphics-card/R9-390-GAMING-8G.html#hero-specification
MSI R9 390 is 277mm long IIRC
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
The card is listed as 12.1 inches (308mm) long on their website. So it would either be a tight fit, or not fit at all.
Thanks all, so do you think I should risk the sapphire or just go for the msi in that case? (I guess I could maybe shave a bit of the drive bay off with something if needed)
The msi 390 also is a 2.5 slot card so make sure you have the vertical room for the card.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
Thanks everybody, after opening my case up and checking everything over again I've decided to go for the msi 390!
