Probably not, but is one able to delete the quoted reply they quoted on their reply? I have a habit of automatically pressing the quote button and then can't delete the quote, and whenever I refresh the page, the reply still has the quote in it..
Intel i7 6700K | MSI Krait Z170A MSI GTX 980 w/ NZXT Kraken G10/x31 Corsair Vengeance LPX 16GB Samsung 850 EVO 500GB SSD/WD Blue 1TB HDD NZXT H440 | K70 RGB/SteelSeries Rival
https://linustechtips.com/topic/566186-being-able-to-delete-quoted-posts/
Had this issue too.
You might be able to control+z it out
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
Hold control and then right click on the quote, it brings up the option to remove a quote from your reply. It's the most convoluted quote removal system of any forum I've ever used.
usually I press that little move the quote thing and after that press delete and the quote goes away
i move into it with the arrow keys then tap the right or down one untill im just out if it again and the i doubble tab backspace, works fine but can be a bit fiddely
Builds:
