FPS sweetspot in a 60hz monitor
Error404
I've been searching about what is the sweetspot in fps for gaming in a 60 hz monitor, I've found this 5 answers.
1.-  60 FPS + no vsync
2.-  60 FPS + Vsync, (but input lag)
3.-  80 FPS  no vsync
4.-  120 FPS (The famous formula " 2 x RefreshRate + 1") (Somehow smother gameplay)
5.- The most FPS the better (Same as 3 but.. very smother)
What do you think is better?, What do you feel is better?
Thanks for answering! xD
i think you meant to say "cant" not "can"
well i tend to use vsynch(no alternatives, i use it cuz i get screentearing), if it locks to my monitors refreshrate(60hz). if i play bf4 for example, the latency becomes noticable, when i look to my side really fast i can feel that it doesn't happen immediately, because how the vsynch works. now if i don't use it, its more "snappy" , there is no latency, at least i can't feel any. that 61fps thing is bs
Locked 60fps is the smoothest you can get with a 60hz monitor without screen tearing. If you want maximum smoothness and little input lag, just turn off v sync.
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
Fixed, thanks
Locked 60
Just now, don_svetlio said:
Locked 60
but the latency.... but i agree... but the latency...
What game? If you mean Dota 2 or CS:GO then by all means, use 300fps like normal people.
but why? you just told me than 60 hz is the best. why 300?, it is smother?
Depends on the game, in games like CSGO where response times are crucial i cap the fps at 120 but in  most other games i just lock it to 60. If its an older game that i can run with ease ill turn on vsync, if its a newer more demanding title that i wont get a constant 60 fps on then ill turn vsync off since its smoother without vsync when you go below 60.
"Give a man a mask and he will become his true self." -Oscar Wilde
CPU Intel Core i5 6600k @ 3.5GHz GPU MSI Radeon R9 380 4GB Motherboard Asus Z170 Pro Gaming RAM Kingston Fury 2x4GB DDR4 2666MHz PSU XFX 650W Storage Seagate 1TB, WD Blue 1TB, Kingston 128GB SSD OS Windows 10
22 minutes ago, Error404 said:
I've been searching about what is the sweetspot is terms of fps for gaming in a 60 hz monitor, I've found this 4 answers.
1.-  60 FPS lock (Cause your monitor can't show more anyways, and you don't overuse your GPU)
2.-  61 FPS lock (Same as 1, but Idk what this fps change)
3.-  121 FPS lock (The famous formula " 2 x RefreshRate + 1") (Somehow smother gameplay)
4.- The most FPS the better (Same as 3 but.. very smother)
5.- 60 FPS + Vsync, (but input lag)
1. prolly the best
2. it creates tear in certain monitors
3. major tearing
4. worse than 3.
5. same as 1.
-sigh- feeling like I'm being too negative lately
Higher FPS will still make aiming easier even if you use a 60hz monitor. Dont know about dota but in csgo everyone does it, ive lowered my settings a bit to get a constant 120 fps in game at all times. Also if you cap your fps your aim will be more consistent since the fps stays the same.
I understand that different games will be different, and yeah, it depends. But can't we unify the answers?, If CSGO feels better with a 120 FPS cap, don't the experience at 120 FPS should be just better in all games?.
6 minutes ago, Moonzy said:
1. prolly the best
3. major tearing
4. worse than 3.
5. same as 1.
So would you play games where the response time matters like CSGO at 60 FPS?
prolly not... for FPS u want more fps as possible
So you think 120 fps is the best?
Even in a 60 hz monitor?
well if u can deal with tearing, higher response time is always better in competitive gameplays
i just play rpg so graphic is everything to me :D
62 with vsync on i find works well, the extra 2fps acts as a buffer against stutter...
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
Do you have a 62Hz monitor?
You mean lower response time, right?
144Hz goodness
shh it was 8 am and i havent had my sleeo ;3
Nope, i can make do a custom refresh 60-75hz though.
