lg g5 vs galaxy s7 speed??
Solved by Darkseth,
Depends on Region.
If the S7 in your region has Snapdragno 820, they will be exactly at same speed.
If its the Exynos, i'd say, maybe a few % slower single Core, but more multicore (because 4 strong cores, instead of 2).
But thats also just a Benchmark number.
In real world and any practical tests, you won't notice any difference.
If you need help to chose between them, do it from other specs. Display panel, size, battery size (was easy for me to pick an exynos S7 Edge over an LG G5 with that small Battery), software features, Camera, etc etc.
Both are high end so... Preference is up to you.
