Building my first gaming pc
If you can stretch that budget a little more and include rebates, you can do this:
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor ($179.99 @ Amazon)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard ($51.89 @ OutletPC)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory ($31.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Video Card: PowerColor Radeon R9 380 2GB PCS+ Video Card ($154.99 @ Newegg)
Case: Fractal Design Core 1300 MicroATX Mini Tower Case ($49.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($19.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit) ($87.95 @ OutletPC)
Total: $623.68
Generated by PCPartPicker 2016-02-19 14:47 EST-0500
Which is an overall much better build. The i5 will serve you greatly for gaming, and while the 4GB version of the R9 380 is great, the 2GB version will suffice for this budget and is a very cheap yet good buy. This build does cut a few corners, but none I'm unhappy about. If you must save money, find a cheaper case or scrounge one.
