Why do some earphones not have freq range of up to 20khz?
Frequency range specs are useless, so I wouldn't read too much into the numbers. Most of the time, frequency range specs are used to enforce prestige pricing; i.e. a manufacturer wants to differentiate SKUs in a product line.
Because differences in audio gear is often very hard to objectively define, this leaves the marketing department of a company with few options but to basically pull specs out of their asses. Normally this means rounding the numbers up so that more expensive products look worth the money; but it can also mean making less expensive products look worse so that the more profitable ones look more attractive.
In the even that a headphone actually only goes up to 16-18kHz, this could just be a side effect of using cheap parts to hit a price point. The extremes of the audible spectrum are the hardest to reproduce, so they are often the first to go in a low quality product. It could also be an intentional compromise, designed to avoid distortion due to driver break-up that would sound even worse than a simple roll-off. As others have pointed out, the music that most people listen to has been degraded by lossy compression schemes that discard the high frequencies anyway.
