NH-D15 temps?
Eeglis
Post your CPU and temps from your NH-D15 here.
I'm kind of concerned about mine, are they ok? 45C idle, non overclocked i7-4790k.
As a case I have Silencio 550
no idea what to put here
45c idle? Thats bad. I run about 20-25 idle with an 4790k overclocked to 4,8GHz and 65 during full load.
Yeah, I'm wondering a bit as well. What RPM you run at idle?
Just now, TheRandomness said:
Idle temps don't really matter, what're your load temps?
70c at their worst. In most of the games I get around 50-63
Those temps are bad. I don't own one.
But remove the CPU cooler and clean the thermal paste from the CPU and the cooler with atleast 99% Isopropyl Alcohol.
And the apply new thermal paste and read the instructions carefully, then mount it properly.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
Not sure, it's at 40% in the bios. So around 400-500 RPM. I have both fans installed, do you have one or two?
It's mounted properly. Maybe I got some old thermal paste on since I didn't use Isopropyl Alcohol to clean the CPU with.
3 minutes ago, TheRandomness said:
High idle temps mean either high ambient temps, poor cable management or shitty airflow. Those load temps are fine.
Cable management don't affect temps.
I have both installed. Spinning idle at around 250-350RPM idle.
Not sure what the problem is.
But again try what I said.
Did you use papper towels? Could have left some bits of papper on the CPU.
Well my room ambient gets up to 26c sometimes. Cable management isn't the best, but it's extremely avreage I'd say.
I used hard paper towels.
Will try to do that.
Post back with results :)
2 minutes ago, TheRandomness said:
Haven't watched yet, but it would make sense that a huge mess of cables would affect airflow.
It would make sense, but nope. It dosen't affect temps.
I built a pc for my friend that uses the NH-D15. He has his air conditioner set to 18c and the cpu temps are 30c on idle. Although its not accurate as his air conditioner is broken.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
