Top 5 140mm "High-Static" PWM Fans : according to you!
Solved by WoodenMarker,
6 hours ago, anandgeforce said:Best of the best, or second best of the best! Gonna get only two of them for my H110i GTX.
Well, if you can afford them, NF-A14's are among the best. The NF-P14S has arguably better tonality but has lower performance.
themasteroftalking ·
1
5
uzivkovic97 ·
Posted in Linux, macOS and Everything Not-Windows4 -
11
OctaviousTheHonorable ·
Posted in General Discussion1 -
4
6
Real_Smoky ·
Posted in Laptops and Pre-Built Systems1 -
TannerMcCoolman ·
Posted in LTT Releases2
