Are these parts fully compatible?
Go to solution Solved by CyberneticTitan,
Looks good to me for both RAM clearance and power.
4000D only comes with two fans. I would perhaps wait to see if you actually need the two additional fans after you buy, you could just wait for good discounts to come for buying those.
Last suggestion, you can get 6000 CL30 for a cheaper price: https://uk.pcpartpicker.com/product/t4bRsY/kingston-fury-beast-32-gb-2-x-16-gb-ddr5-6000-cl30-memory-kf560c30bbk2-32
Country: UK
Games, programs or workloads that it will be used for: Gaming
https://uk.pcpartpicker.com/list/FcpJWt
Just trying to find out if these are all good options and compatible. Will I have any RAM clearance or power issues with this? Also will I need more fans or is this ok as is?
https://linustechtips.com/topic/1571619-are-these-parts-fully-compatible/
14 minutes ago, gh0st013 said:
Country: UK
1000w psu is overkill and you should add more fans to the case or change the case to phanteks or a 5000d/x
25 minutes ago, gh0st013 said:
Country: UK
Save a bit with a CPU cooler that has the same performance on the 7800X3D.
Consider better performing memory that includes EXPO profiles.
Consider a case that comes with 2x160 front intake fans and a 140 rear exhaust fan.
An 850W PSU is more than enough.
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor (£319.00 @ Amazon UK)
CPU Cooler: Thermalright Peerless Assassin 120 Black 66.17 CFM CPU Cooler (£42.00 @ Computer Orbit)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard (£149.99 @ Amazon UK)
Memory: ADATA XPG Lancer Blade 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£109.00 @ Computer Orbit)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£163.95 @ Amazon UK)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card (£769.00 @ MoreCoCo)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case (£89.00 @ Computer Orbit)
Power Supply: Thermaltake Toughpower GF3 TT Premium 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£99.98 @ Scan.co.uk)
Total: £1741.92
Generated by PCPartPicker 2024-05-26 21:49 BST+0100
Thanks a lot
Total: £1741.92
Alright...I'll look into alternate cases and drop my PSU
1 hour ago, gh0st013 said:
Country: UK
You want DDR5-6000 CL30 for these AM5 cpu's. The 4000D is a hose job ... wanker case in the King's English due to the fan's that case comes with and a 850W psu is more than sufficient for your build.
CPU Cooler: *Deepcool AK620 ZERO DARK 68.99 CFM CPU Cooler  (£59.00 @ Computer Orbit)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£102.06 @ Amazon UK)
Storage: *Lexar NM710 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£112.49 @ CCL Computers)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  (£89.00 @ Computer Orbit)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£109.00 @ Computer Orbit)
Total: £1709.54
Generated by PCPartPicker 2024-05-26 22:32 BST+0100
A better look at those components.
https://www.deepcool.com/products/Cooling/cpuaircoolers/AK620-ZERO-DARK-High-Performance-CPU-Cooler-1700-AM5/2022/16124.shtml
https://www.techpowerup.com/review/lexar-nm710-1-tb/
https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5
https://lian-li.com/product/lancool-216/
