can anyone help build a chaeap £400 server for home use
Solved by Necrodead,
For my 'home server' I installed windows on the cheapest AMD processor and mobo I could find with sata 3, stuck an old stick of DDR3 in it and am using an old SSD for a boot drive. I stick all my HDD's on it (non-raid) and have it connected to my network without a monitor. I already have file access set to read/write for the network, so I can save files to it as well as pulling them off. I use a 3tb drive for a separate backup.
Thats probably about all you could do for 400 quid. maybe get a better processor, but I was more interested in the 8x sata 3 ports I could get on a cheap AM2 platform.
