Where should i put dual kraken x41 and single x61 in 760t
Solved by W-L,
so replicate your diagram?
@W-L
That's up to you mainly if you wanted to try and more the heat out as much as possible thekeemo's with the two GPU rads up near the rear and top will work well for that but will still bring in some heat from the CPU at the front. The diagram I made was to try and keep things neat with the tubing runs and give positive air pressure.
Featured Topics
3
bleedpurple ·
Posted in Storage Devices2 -
geoffery ·
Posted in Troubleshooting1 -
IPQ ·
Joey__ ·
Posted in Troubleshooting5 -
83y ·
Posted in Troubleshooting0
