Good CPU and MOBO combo for 3d rendering and casual gaming
Solved by SheepRSA,
$300+ and in your case you might want to make a decent upgrade now so you don't have to in the near future. For casual gaming and mainly editing I would recommend more cores over single core performance so something like a non K i7 over a K i5 for example. Getting an i7 6700 for example would allow for good headroom in terms of expandability and overall longevity of the system especially if you want to up your editing workloads. Also Welcome to the forum!
Thanks for the warm welcome!
I'll keep that in consideration while shopping around. Anything specific i should look out for in a motherboard besides compatible sockets with my chosen CPU?
sheep
