8-pin CPU power doesn't fit Mobo (EVGA 650 GQ)
Solved by GzeroD,
As can be seen in the pictures, the connector that connects to the power supply would fit the motherboard, but the one that's supposed to connect to the motherboard doesn't fit entirely.
I don't see how it wont fit the motherboard. one side of the connector has the square (keyed) blocks too make sure you don't plug it in incorrectly. all 8 pins are not keyed identically but there are no square connectors where there should be irregular hex pins. It should just slot in.
