Using PC as Space Heater
Solved by Jacktastic-Mofo,
So after doing all my math and such I was able to calculate that with your PC putting off about 450,000j of energy per hour (about what you'd expect with a 250w draw from the wall) I was able to calculate the you could expect a 14.629°c rise in temperature in your 36 cubic meter room, however you have to take into account any potential thermal leaking through windows, door frames, walls, etc. So realistically you'd see a 10°c rise in temperature that seems rapid initially however eventually slows down and stops.
Also keep in mind that this would not be linear as your room would eventually reach thermal equilibrium. Here is the math / equations-
