Should I get an Lg Ultrawide monitor or an 1440p 144hz monitor?
CoolBeans72
I recently got some money, and am looking for a new monitor. Which monitor should I get? I mainly do gaming but do some productivity.
Go for gold and get an ultrawide, 1440p 144hz monitor.
I don't have that much money :)
Between resolution, refresh rate, and size/ratio, The most important is size/ratio , it's not gonna do you good if you don't like the size and ratio. AFter that is refresh rate, 144hz refresh is alot smoother than 60hz, how smooth you ask? Once you get use to 144hz, 60hz will look like a powerpoint slide show. You don't even have to be gaming, moving your mouse on the desktop looks like a slideshow on 60hz so there's that to consider.
Best of both worlds would be ultra wide 144hz, but I don't think that's available, I would suggest 144hz. Once you go 144hz, you can't go back.
2560 x 1080
or
3440 x 1440?
3440 x 1440
ultrawide
1920x1200 @ 120hz is needed for me ;w;
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
I'd avoid the 2560 x 1080's, since they're measured horizontally the vertical size of the monitor suffers a lot.  I was going to get one and went to best buy just so I could look at it (literally the best place in town unfortunately) and it looked like a toy it was so small vertically.  I would've been really disappointed if I ordered that online and didn't know.  I just got a cheap 1080p 144hz tn display and I'm blown away by the difference.
3440 x 1440 would be dope
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
I went back and had no problems. :D
Although i still have my 144hz, I mainly game on my U2515h now.
Corsair 760T White | Asus X99 Deluxe | Intel i7-5930k @ 4.4ghz | Corsair H110 | G.Skill Ripjawz 2400mhz | Gigabyte GTX 970 Windforce G1 Gaming (1584mhz/8000mhz) | Corsair AX 760w | Samsung 850 pro | WD Black 1TB | IceModz Sleeved Cables | IceModz RGB LED pack
