Ram speed
Solved by EliminatingAngels,
I would go for the 1866mhz one. You also have to keep in mind cas latency (IE cl 9). Higher Mhz = better. Lower cas latency = better.
for example:
1600mhz cl 9 is better than 1866 cl 11
1600 cl9 is about the same as 1866 cl10
and 1600 cl9 is worse than 1866 cl9
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
