Razer Tiamat Ear Cushion Replacement?
matto97
I went on to the Razer store but they dont have any replacement ear cushions for sale, why not?
All the fake leather is pealing off and one of them i just had to glue the pad to the plastic part of the cushion as a temp fix and went to go buy replacement ear cushions but they dont sell them.
Why?
And where do i find some, i get a expensive headset here that i cant use, Has to be available in Australia though.
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
Your best bet is to contact razer.
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
I suggest trying ebay, they have some. Will have to come from china though
muh specs
Gaming and HTPC (reparations)- ASUS 1080, MSI X99A SLI Plus, 5820k- 4.5GHz @ 1.25v, asetek based 360mm AIO, RM 1000x, 16GB memory, 750D with front USB 2.0 replaced with 3.0  ports, 2 250GB 850 EVOs in Raid 0 (why not, only has games on it), some hard drives
Screens- Acer preditor XB241H (1080p, 144Hz Gsync), LG 1080p ultrawide, (all mounted) directly wired to TV in other room
Stuff- k70 with reds, steel series rival, g13, full desk covering mouse mat
All parts black
Workstation(desk)- 3770k, 970 reference, 16GB of some crucial memory, a motherboard of some kind I don't remember, Micomsoft SC-512N1-L/DVI, CM Storm Trooper (It's got a handle, can you handle that?), 240mm Asetek based AIO, Crucial M550 256GB (upgrade soon), some hard drives, disc drives, and hot swap bays
Screens- 3  ASUS VN248H-P IPS 1080p screens mounted on a stand, some old tv on the wall above it.
Stuff- Epicgear defiant (solderless swappable switches), g600, moutned mic and other stuff.
Laptop docking area- 2 1440p korean monitors mounted, one AHVA matte, one samsung PLS gloss (very annoying, yes). Trashy Razer blackwidow chroma...I mean like the J key doesn't click anymore. I got a model M i use on it to, but its time for a new keyboard. Some edgy Utechsmart mouse similar to g600. Hooked to laptop dock for both of my dell precision laptops. (not only docking area)
Shelf- i7-2600 non-k (has vt-d), 380t, some ASUS sandy itx board, intel quad nic. Currently hosts shared files, setting up as pfsense box in VM. Also acts as spare gaming PC with a 580 or whatever someone brings. Hooked into laptop dock area via usb switch
Lol they look sketchy af
To be honest.
It's best to either buy some other cushions or just get another headset.
My Blackshark cushions bursted, contacted Razer...
Long story short,
6 months later and i still don't have my spare ear cushions... And now i have my hyperx clouds..
Take from this what you'd like.
My friend got his replaced by razer directly. Try contacting them. It did take a while though about 2 weeks.
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
They do. I suggest finding headphones that have similar ear pad shape and seeing what you can find there if you have no luck with razer. I used some valuer sony v6 earpad for some other things, for example. Those are much more readily available in multiple varieties.
muh specs
All parts black
To be honest.
Long story short,
Yeah seen a lot of stories like yours :/
I emailed them and see where it goes, if not i might just try and find some real leather cushions and splice it to the plastic back of my current ones with some glue :P
