2.1 to 5.1/7.1 surround sound.
By
Yoo Song Won
in Audio
in Audio
Solved by Enderman,
They're pretty old but they're Yamaha YST-M100's with sub-woofers...
from what i can see on google images it looks like they have RCA inputs
that means that if your motherboard has 7.1 audio out, all you need are some 3.5mm to RCA cables and place the speakers surrounding you, and you get 7.1 audio
just make sure you plug the correct speakers into the correct outputs
Featured Topics
Shadow1789 ·
Posted in Cooling3 -
7
1
1
7
6
3
INotPablo ·
Posted in CPUs, Motherboards, and Memory10
