My first overclock, need someone to help me out
Solved by LeapFrogMasterRace,
Overclock the core until it crashes then slowly back off until it is stable only then should you overclock the memory otherwise if you get problems you won't know if it is due to the memory oc or the core oc.
-You should drag the power limit % all the way up if you want a higher oc it wont severely shorten the gpu's lifespan and most people do this.
-It is highly unlikely you will just straight up brick your card unless you manually increase the voltage pretty high.
