So i finaly finished downloading fallout 4 (not from steam) and it works but the text is in russian and i can't speak russian. the voices however are in english but i want the text in english as well. i have tried messing with the configs but it always crashes
probably because you pirated it.
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542753
Pirate a Russian Dictionary?
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542763
Did you. Pirate it? :o
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542767
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542768
yeah this should help https://translate.google.co.uk/
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542775
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542787
JUST TELL ME HOW TO CHANGE THE LANGUAGE
no, you are basically a robber as far as i am concerned.
BUY THE DAMN GAMES, AND IF YOU ARE TOO POOR, THEN DONT THINK ITS FREE
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542819
i forgot that everyone on this forum has enough money to buy a $3000 machine and any game they want
boohoo
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542820
its not my fault that i can't afford it
doesnt meen you should pirate it.
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542827
Go to where you pirated it and find out how to do it. Don't ask the community to help you with your pirated game.
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542839
Locked. We do not allow users to publicly help other users with their pirated software - it is heavily frowned upon on LTT. Sorry.
https://linustechtips.com/topic/487487-fallout-4-language-help/#findComment-6542855
Guest
