Does xbox one controller with 3.5mm jack work on PC ?
Solved by elfensky,
I wonder if the dongle registers as it's own speaker device which you can select in the sound panel, or if Windows automatically switches to it.
EDIT: This article says that sound is supported.
With the Xbox Wireless Adapter for Windows, you'll simply plug the Adapter into the USB 2.0 or 3.0 port of your Windows 10 PC and bind the Adapter to your Wireless Controller to enable the same gaming experience you're used to on Xbox One, including in-game chat and high-quality stereo audio.
