Why does no one make a 90 degree elbow for ANYTHING!!!  I can find custom sleaving and cable extensions from half a dozen places but why cant anyone make a simple 90degree bend!!!
Think about how much cleaner your cable management would be if your 24pin had a 90 degree bend in it instead of a big curve...  Or what if your 6/8 pin GPU connectors had a degree so they dropped strait down or up?  People will take all the time making hard pipe cooling with nice clean lines but when it comes to cable management all you can do is make the gentlest smoothest arc...  Gahhah
Sorry that is all!
Computer: http://pcpartpicker.com/p/ZczbWZ ~$950
Computer w/ Peripherals: http://pcpartpicker.com/b/mZNNnQ ~$1650
Case: Blue s340 painted black CPU: 4790K OC to 4.5MHz Cooler: Dark Rock 3 GPU: Powercolor R9-290 MOBO: z97 MSI Gaming 5 RAM: Fury HyperX 2x8GB 1866Mhz PSU: Corsair rm750x Storage: 250GB 850 EVO & 1TB WD Black HeadPhones: HD598 SE Speakers: MAckie CR4 SE Keyboard: K70 Cherry-Brown Mouse: G9x Fans: Prolimatech Vortex 140mm
https://linustechtips.com/topic/474257-cable-rage/
Oh except for this guy who did more then *rage* props to him for going the distance
https://linustechtips.com/topic/474257-cable-rage/#findComment-6354968
Sorry that is all!
What kind of cable are you talking about when you say you need a 90 degree elbow?
As for the 24 pin and the 6/8 pin connectors, inserting the metal connectors bent at 90 degrees wouldn't work so well. They wouldhave to make the adapters by injection molding the plastic of the right angle adapter around the metal connectors.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/474257-cable-rage/#findComment-6354971
Sorry that is all!
If you want straight bends you will to make it yourself since they are fairly non-standard, Evga is the only one I know that does a 90 degree motherboard connector. If you are going for straight runs and 90 degree bends I have seen someone do hardline cabling before using insulated solid brass wire it looks amazing but the work to do that is insane.
http://www.overclock.net/t/1524330/diy-right-angled-24-pin-8-pin-power-connectors-has-anyone-done-this
https://linustechtips.com/topic/474257-cable-rage/#findComment-6354978
-PIC-
This build here, probably the cleanest and most unique wiring system you will see:
http://www.overclock.net/t/1445135/cooler-master-cm690iii-modded-edition#post_21246532
https://linustechtips.com/topic/474257-cable-rage/#findComment-6355040
No, I've seen SingularityComputers completely remove the pins and connector on the motherboard are solder wires from the back to make it 100% clean
Cant top that
https://linustechtips.com/topic/474257-cable-rage/#findComment-6355109
Cant top that
Where is this! I got to see how that works now.  :o
https://linustechtips.com/topic/474257-cable-rage/#findComment-6355139
Where is this! I go to see how that works now.  :o
i cant remember which build it was, but heres his channel
https://www.youtube.com/user/SingularityComputers
https://linustechtips.com/topic/474257-cable-rage/#findComment-6355200
It's a GTX 760 : /
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/474257-cable-rage/#findComment-6355330
