Hi guys,
When i run Prime95 on my i74770k at STOCK the temperatures boost right up to 90-92c!
I have an Corsair h100 cooler so that should not happen..
Anyone have any idea what this can be?
i7-4770k stock
Asus Maximus Vii Motherboard
16gb corsair 2400 pro
https://linustechtips.com/topic/473332-4770k-temperature-problems/
Hi guys,
i7-4770k stock
Follow your own topics if you want notifications.
And re-seat the cooler.
P95 may still up the voltage on Haswell CPUs to ensure stability. I suggest something else like IXTU or AIDA64.
you DO NOT run prime 95 on intel CPUs
Hi guys,
i7-4770k stock
Prime95 is not recomended for Intel CPUs, SPECIALLY Haswell, it overvolts the chip and can damage it. Use OCCT, XTU, RealBench or Aida 64, If you still get stupid high temps, then check the voltage, if it's normal, reseat the cooler.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
Hi guys,
i7-4770k stock
NEVER RUN Prime 95
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
You can run P95 on Intel CPUs, just not Haswell based Intel CPUs.
its not recommended for all intel CPUs in general because it causes the adaptive voltage to increase beyond the stock voltage limit
linus has talked about this dozens of times
it is not just haswell
the only difference is that haswell has a tendency to heat up more because of the IHS TIM
prime 95 should still not be used on any CPU
Yes, that's using adaptive voltage. Your post just mentions not using it on Intel CPUs in general which isn't true. It's only a problem if you're using adaptive voltage and/or a Haswell based CPU. In my situation, P95 doesn't affect me because I'm using Ivy Bridge and static voltage.
but static voltage is bad for a CPU...
makes it run hotter and have a shorter life span
Haswell really, others are mostly fine, voltage hurts our beloved Haswell most.
OP, that's probably the reason why you're getting stupid temps. What's your idle temps?
did you not read the other post I made above?
Well i ran the test in Aida now just for a few min, the temperature in on the high 50c when stress testing cpu.. maybe i have some room to overclock then :) thanks alot guys
Awesome, it was fucking p95, under 60 on Aida64 is fantastic, you should have room for a good overclock
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
