Do i need thermal compound
Solved by Enderman,
On a 5820k ? Oc, if i get mx4 isit worth it?
mx4 would be better, yes
but only by a few degrees
if you think thats worth it, then buy some, otherwise just use the stuff that came with the s36
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
