3.5mm cable works on PC but not on phone
aidenrelkoff
i bought a 3.5mm headphone extension cable (female to male) its about 1m. If i use it on my PC headphones it works fine. but when in my phone it glitches/lags out and the volume plays out of the speaker instead of the headphones for about 1.2 seconds then pauses. It randomly changes volumes and does weird things all around.
What could possibly be the problem???
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
Have you really pressed it in far enough?
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
3 or 4 pole?
cable is 4 pole, desktop connection is a 3
yes
What phone?
Moto G
yes
4 pole extensions are hit-or-miss usually.
Primary: Lenovo T61 / Intel Core2Duo T7200 @ 2.2GHz / 3GB DDR2 / NVIDIA Quadro NVS 140M / Fedora 22 <<<< THE WHITE KNIGHT
Secondary: Compaq Presario CQ56 / AMD V130 @ 2.3GHz / 2GB DDR3 / AMD Radeon HD 4250 / Windows 8.1 <<< THE FORGOTTEN HERO
Probably what Gala said. I know with my iPod touch, some headphones don't properly work on it.
Like if half of the song was missing, or it was played in some very long corridor?
Yeah that is 4 pole magic.
make sure its plugged in all the way and that the case isnt interfering
Pretty much where only the subchannels were playing (like with how surround sounds work)
Yes, exactly, 4 pole swag right there.
There is a workaround tho, solder a 3 pole on it.
