CPU Cooler for under 40€?
Strom
This is my build and i'm and everything is chosen but i'm not sure about cpu cooler. 212 evo is classic but is there something that is better than it or about as good as it in the same price range? Link to my build: http://pcpartpicker.com/p/4rdtGX
I'm Linus too. (:
Cryorig H7 :D
It seems good but does it fit?
I'm Linus too. (:
If pcpartpicker says it does, it does :P so give me a moment. Yeah it does.
I'm using a german shop called Mindfactory and they dont sell Cryorig H7 ): same with 212 evo
I'm Linus too. (:
imo, i would get a u12s or the phanteks ph_tc12dx instead
u12s and tc12dx goes over my budget ):
I'm Linus too. (:
well if you want to be able to overclock your cpu to its full potential, you're going to need a better cpu cooling solution. those are the two that will allow you to get a solid overclock. that or the h60 from corsair. save up more money or scrap something else on the list.
there are people around here who say that they've overclocked their i5 with the 212 evo to 4.6 ghz with great temps, but i don't know... give it a shot
BigDay
theres a german PCPP, and it supports mindfacory ;)
This.
The U12S is a nice cooler that is good for non-overclocking. It's a bit expensive but worth it. If you want to overclock it in the future, then I would recommend an air cooler instead of AIO. My brother has the U12S and he's happy with it, he plays mostly CS Source though.
http://www.relaxedtech.com/reviews/noctua/nh-d15/8
Question: is be quiet pure rock good?
And if possible i'd like to go under 30€ if possible and i wont oc much, only a bit
I'm Linus too. (:
212 evo
Hyper 212 evo . Period.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
Overall its better than 212 Evo. Less noise, more cooling performance. Only thing is that its often priced bit higher than 212.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
