Ok so kinda odd question that i cant seem to find answers on ANYWHERE.... for thermal compounds what is the best, cost not a factor.
I currently use artic mx-2...
But i was looking at IC diamond, coollabratory liquid metal, gelid gc extreme...
So whats the difference, i know the coollabratory is conductive so i probably wont use that... but stuff like IC diamond i wouldnt mind using on my cpu and gpus when i water cool them
https://linustechtips.com/topic/460042-thermal-paste-questions/
Theres literally no difference lmao...
Good quality paste is good quality paste, brand does not matter as long as its a trusted one.
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6173984
doesnt matter who does the reviews, testing or anything.. the noctua one is always near the tops no matter what kind of testing is done. as an added bonus its just really easy to work with unlike some other funky ones.
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6174004
the best are the liquid metal from coolaboratory
they are difficult to apply and dangerous cause it can kill your mobo/CPU
but they have a big difference compared to regular thermal pastes
the best "regular" thermal pastes are NT-H1 and MX-4
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6174007
If you're after the best for the CPU, Indigo Extreme is ranked number #1. The stuff isn't cheap and is like 20 dollar for 2 applications. Really not recommended unless you have a crazy water cooling set-up and want to go balls to the wall.
For everything else, it's really a 1-3c diff with some of the cost not being worth it. A good well applied TIM will out perform the very best if applied bad. In terms of good temps and easy to apply, the Noctua stuff is my personal fav.
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6174032
CLM (and all liquid metal type's) are generally much better than other pastes, if and ONLY if delidding is done to the cpu.
I personally would never use IC diamond because scratching the shit out of my cpu/gpu and not even getting better cooling out of it isn't cool to me.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6174064
Any kind of scratches that something like that would do would be barely noticeable...thats assuming they are even noticable with the naked eye.
Hell the whole point of termal paste is to fill in scratches on both surfaces for better heat transfer
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6174093
They are EXTREMELY noticeable. It obviously doesn't matter for using it again later, but visually it's insanely evident.
I used it once and threw it out. Not better than other cheaper ones, and seeing that damage (even if its only superficial) really grinds my gear.
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6174112
I've been using some white thermal paste for years now.
It's the kind most commonly used in electronics, but it seems to do its job pretty well on CPUs and GPUs. Wouldn't recommend using it unless you know what you're doing and you know the TIM's limits and shortcomings.
Sticking to consecrated branded TIMs is recommended since you know what you get
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6174150
Noctua NT-H1 is good and affordable (unlike other Noctua products), but pretty much everything from a reputable brand will do the job excellently, with little or no discernable difference between them.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6174812
I just wouldn't buy those 99p ones off ebay :P May as well use blutak instead.
|CPU| i7 4770K @ 4.4GHz |Motherboard| Asus Z87 MAXIMUS VI HERO |RAM| Corsair Vengeance 16GB 1866MHz |GPU| EVGA GeForce GTX 770 2GB
|HD| 256GB SSD 850 PRO |Sound| Creative Sound Blaster Z High Performance |Case| NZXT Phantom 410 |OS| Windows 10 x64
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6175571
This video is a couple years old, but it might help shed some light on actual performance differences between compounds.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6175638
I never quite understood why they were using an Intel CPU for that test, and why other thermal paste tests do the same thing. Surely the higher TDP of AMD processors makes them more ideal for this kind of test, as it would make the differences between thermal compounds easier to spot, and lessen the relative size of the margin of error...
https://linustechtips.com/topic/460042-thermal-paste-questions/#findComment-6175671
