I'm carrying out a short survey on how effectively AMD use the marketing mix for my business management exam. Would be great if you could help contribute to it so I have a better chance of passing, its only 10 questions long and are basically yes and no answers so would only take 2 minutes .
Thanks
https://www.surveymonkey.com/r/DX8BWSZ
https://linustechtips.com/topic/455692-amd-effectiveness-exam-help/
done
done
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
Done. :D
Done. Good luck. :)
Done, good luck with it.
PC Specs: CPU: Intel Core i7 3930K OC @ 4.4 GHz | CPU Cooler: Corsair H105 | Motherboard: ASUS Sabertooth X79 | GPU: 2x SLI Gigabyte GTX 760 | RAM: Mushkin Redline 2x4GB 1866 | Case: Cooler Master HAF X | PSU: SeaSonic X Series 750W | Storage: A-Data XPG 120GB  & WD Blue 1TB | OS: Arch GNU/Linux || PC Part Picker & 3D Mark Score
thanks for those who've helped so far
Personally think you should ask around a bit to get a good mix on who likes what, there is bias to be aware of. You also haven't added sections on the people filling out the survey which is going to harm your results, your questions are relevant but without putting your findings into sub sections it will harm your grade.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
thanks for the feedback, I'll speak my teacher
