How to turn glossy bezel matte?
Phobophobic
Go to solution Solved by Leonard,
This.
We're talking about a BenQ GW2765, btw. I'd think the best way would be to dismantle it and sand it down, but I'm not sure how to go about doing that or if it's even the best option. What other ideas do you guys have?
Sanding it would be the best bet, yeah.
Intel I9-9900k (5Ghz) Asus ROG Maximus XI Formula | Corsair Vengeance 16GB DDR4-4133mhz | ASUS ROG Strix 2080Ti | EVGA Supernova G2 1050w 80+Gold | Samsung 950 Pro M.2 (512GB) + (1TB) | Full EK custom water loop |IN-WIN S-Frame (No. 263/500)
Sand it or plastidip, plastidip is quite easy to do can't really screw it up as hard as you can screw up sanding.
Completely forgot plastidip was a thing. Thanks for bringing it back on my radar.
that's what i did to my monitor. it looks great from viewing distance but you can see that its just scuffed up plastic when you look closer. :D
who cares...
