Extreme Overpriced Rendering/Game Developing machine
your opinion was very nice and made me reconsider some thing.
the problem is in my country we dont have any providers for servers, so im gonna build it my own.
i have i background in normal pcs but never with servers or rendering machines.
Some engines need Cpus
and others need Gpus
some need cuda
other need open gl.
Building a server like this wouldn't be better than just a 5960X?
+i need that extra ram power
If you were a company with many users, then I would say central server with mad rendering power. If that were the case, then rock on with dual Xeons and a Titan X in there.
However, if you're a lone developer, I'd say it's not worth the risk. What happens if you fail after the first game? You've just dropped 60k on a server you can't fucking use.
If the 5960X can't cope with that kind of development, then a Xeon server might be worth. Actually, not a server, a workstation. However, the 5960X is no slouch, so I don't really doubt its abilities.
5960X for mad rendering + Titan X for double floating precision (and monster VRAM). That should have you sorted for most of what you do.
I would also invest in a NAS. It would suck to work on something and then lose data.
