I think it looks stupid, puts dust on top of your gpu's because there is never a filter there and opening the door is hard.
https://linustechtips.com/topic/439366-a-side-fan-is-good/#findComment-5890532
depends on where. I had an old case that used 80mm fans. it was on the clear side window that they put a place for a side fan and it was over the CPU. I rotated the side window 180 degrees so it was in the bottom right of the side panel and I used a radial fan on it so it moved air to the GPUs
https://linustechtips.com/topic/439366-a-side-fan-is-good/#findComment-5890562
If you have the option, mount it.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/439366-a-side-fan-is-good/#findComment-5890627
do it! try both intake and exhaust depending on where exactly the fan lines up.  If it is just below the GPU then let it blow in onto the fans, if it lines up straight with the side of the gpu than I find that exhaust works better since GPU's exhaust their air out the sides of the card and then the fan can pull the heat straight out.  made a (negligible) 3c difference in gpu temps and about 2c in cpu temps for me
edit: im assuming you do not have a reference style card?  if that were the case I'd intake it all the way
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/439366-a-side-fan-is-good/#findComment-5891283
I've put a fan on the side panel and took it off after one day b/c of dust.
CPU: Intel I7 4930k 4.4GHz | Motherboard: Asus x79 Deluxe | Ram: G.Skill Ripjaws Z Series (4x4GB) 2400mhz 10-12-12-31 | GPU: EVGA GTX 770 SC |
Case: Fractal Design Define R4 | Storage: Samsung 840 250GB & WD Velociraptor 1TB | PSU: Seasonic Platinum Series 860 |
Cooling: Noctua NH-U-14S Two Fans | Case Fans : 3 Noctua NF A14 FLX  | OS: Windows 7 Ultimate
https://linustechtips.com/topic/439366-a-side-fan-is-good/#findComment-5894547
