New build, unsure if card will fit in case?
Shaur
This is my friend's current build: http://uk.pcpartpicker.com/p/jq2tTW
Will the 980 fit into the R4? And if possible can you proof the build?
Motherboard: Gigabyte GA-Z97X-UD3H ATX LGA1150 Motherboard  (£109.28 @ Dabs)
Storage: Crucial MX100 512GB 2.5" Solid State Drive  (£152.34 @ Aria PC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card  (£377.99 @ Aria PC)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  (£9.36 @ CCL Computers)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£74.95 @ CCL Computers)
Monitor: Asus VX228H 60Hz 21.5" Monitor  (£115.99 @ Amazon UK)
Total: £1258.55
Generated by PCPartPicker 2015-08-27 15:26 BST+0100
The Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case supports video cards up to 430mm long, but video cards over 295mm may block drive bays. Since the Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card is 312mm long, some drive bays may not be usable.
you're gonna be taking out the top drive bay for airflow either way.
EDIT: may i point you to the more refined define R5 as a possibility as well? master race.
if its on pc part picker it will fit pc part picker only allows u to pick compatible parts
Case:- 4U Rack Mount Case | Cooler:- Antec Kuhler H600 | CPU:- Intel i5 4690K @ 4.50GHz GPU:- Zotac GeForce GTX 970 4GB AMP! Omega Core Edition @ 1449MHz | Motherboard:- MSI Z97S SLI Krait | PSU:- XFX XTR 650W Gold | RAM:- HyperX DDR3 1866MHz 4GB White (x2) Black (x2) | Storage:- Kingston V300 120GB | Storage 2:- Seagate FireCuda 1TB | Build Log |
Just becouse i saw the motherboard you have is the same as i got, it might be failing after 6-7 days, but flashing the bios to the latest version fixed this issue (bios dident boot before 3-4 mins after power button was pressed)
Back-end developer, electronics "hacker"
