Does it or do I just suck at applying thermal paste? I remember a guy taslking about thermla paste burn in. Not sure though.
EDIT:
also my speedfan says 75°C GPU temp and my afterburner / Kombustor says 50°C
how do I check who is right?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/433349-does-mx-4-thermal-paste-require-burn-in/
I have literally never heard of this...
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
have you seen the edit?
3.Use
No, I'm using mine right away without issues
CPU: i7-4790k || Mobo: MSI Gaming 5 Z97|| Ram: GSkill Ripjaws X 16GB (2x8GB) || GPU: Sapphire Tri-X r9 390x || Case: CoolerMaster cm storm scout 2 || Storage: samsung evo 850 500GB , WD Black 3TB , WD Green 2TB , WD 1TB external (backups/Media) , Seagate 1TB external (Backups) || PSU: Seasonic X-Series 750W 80+ GOLD || Displays: Samsung C24FG70 , Dell U2414H || Keyboard: Logitech G810 || Mouse: Logitech G502 proteus spectrum || Headset: Logitech G633
Burn in? what? I am 99% sure that doesn't exist and will barely make a difference if it does, maybe like 1 degree or something
EDIT:
Use CPUID HWMONITOR and/or GPU-Z
there is something called "burning in" thermal paste it means just use it for a while...
yes I mean that. So essentially the temps will go down after a few days?
3.Use
You heat up a piece of metal at 50°C then at 75°C, you touch both of them and see how they feel.
Now touch your GPU and you should know whether it is 50°C or 75°C, simple as that.
I take no responsibility of any accidents that may happen carrying out the process above.
Yes this is a troll post.
GPU Z says speedfan is right.
3.Use
Every normal thermal compound needs to "burn in", but it's only 1-2degrees max difference.
So do I just suck at applying thermal paste since my temps have risen by ~10% after applying?
before 100%Fan speed and ~100% load equals ~60°C
now equals ~70°C
3.Use
Maybe :P did you apply enough?
or too much etc
aio's sometimes need "burning in" for example just leave it at idle so the thermal paste hardens and gets gud on the cpu so it cools it efficently
GPU. Btw I just changed the compound for my GPU.
3.Use
or too much etc
idk but I would know if I ripped it out o ma system AGAIN and checked on it but well the old paste looked pretty shitty and bubbly so I am surprised this seems to work worse than that.
3.Use
or too much etc
have you seen the EDIT?
3.Use
how big is it? rice size is gud
it was more than a dry piece of rice.
3.Use
You need more for a GPU than a CPU
;p lol
to much. More like a 1cm long really really small bean.
3.Use
but my GPU core is way smaller thn my CPU
gtx 770
vs
i7 3770k
3.Use
gtx 770
vs
i7 3770k
But what you see on the CPU is a heatspreader, which is in contact with the die which generates the heat. This means you don't have to cover the entire CPU heat spreader, but with the GPU you have to cover everything in an even thin layer because there's no heatspreader. What you see is the die itself!
Two crosses is usually what's used when applying thermal paste to a GPU die.
When in doubt: C4
