What will 12gb of vram do for me?
Solved by ace_cheaply,
Vram is used to store the textures of the game for quick loading when you are moving throughout the game "world." More Vram allows you to set the textures to the highest qualities, while still having fast access to all the data without having large fps spikes and dips, assuming your gpu can process it all. However, no games are using even the 6gb limits of the 980ti, so the other 6gb on the titan x is just overkill unless in a professional environment.
